Couldn't reduce with pivot and group
Below code is perfectly working and separating users table with “pivot” and “group”.
from(bucket:"statistics:daily")
    |> range(start:-1d)
    |> filter(fn: (r) => r["_measurement"] == "players")
    |> group(columns: ["user"], mode: "by")
but whenever I try to “reduce” it, Flux says the fields are empty.
Latest code
    |> range(start:-1d)
    |> reduce(fn: (r, accumulator) => ({
                    user: r.user,
                    _time: r._time,
                    _measurement: r._measurement,
                    _field: r._field,
                    _value: float(v: r._value) + accumulator._value
    }), identity: {_time: now(), _measurement: "", user: "", _field: "", _value: 0.0})
Latest code error (NOTE: There are no empty fields or values, I’m sure about it. If you use this code without reducing, it’d work as expected.)
runtime error @6:8-12:87: reduce: null values are not supported for “_field” in the reduce() function
Even I check and set the default “field”, Flux continues to say “null for _value”. I guess it drops all the things whenever I switch to “reduce” aggregate.
Is it impossible to use reduce with pivot and group?
Hi @Duck,
This is due to the fact that _field and _value are considered null when you pivot by field. let’s take a look at my current data:
Before the pivot you can see _field and _value are represented accordingly and would work against your reduce. After the pivot toy can see we drop the _field and _vaue field. These are replaced by the column jetson_CPU1 with the values represented in this field.
Here is an example of using reduce with a pivot before.
raw = from(bucket: "Jetson")
  |> filter(fn: (r) => r["_measurement"] == "exec_jetson_stats")
  |> filter(fn: (r) => r["_field"] == "jetson_CPU1")
  |> last()
  |> yield(name: "before_pivot")
  |> yield(name: "After_pivot")
raw
                    _time: r._time,
                    jetson_CPU1: r.jetson_CPU1,
                    _value: float(v: r.jetson_CPU1) + accumulator._value
    }), identity: {_time: now(), _measurement: "", jetson_CPU1: 0.0, _value: 0.0})
      |> yield(name: "After_reduce")
Note if you wanted to do it your way which is perfectly reasonable then you should pivot after reduce.
Thank you so much for the fast answer, it helped me. I’ve figured out how to deal with it and write an aggregation in Java language.
The problem I am facing now is to use to to transfer my data to another bucket. After using pivot, group, and reduce, it is almost impossible to transfer my grouped and reduced data(Example: ‘_result, user=1’ and 'result, user=2).
Is there a way to transfer aggregated data to another bucket? I can do it but it just gets the latest field. For example, if I have 3 users grouped by the “user” field, it writes “user3” only, not “user1” and “user2”.
BEFORE (bucket: daily)
AFTER (bucket: overall)
No problem at all. Could you try ungrouping before the to() function? So essentially do reduce() then
|> group() //ungroup
then do to().
Ungrouping works but the result is the same. It just wrote the last user instead of all users.
BEFORE
AFTER
I’ve kind of solved with using experimental.to without regrouping.
After taking a look at it, it is not solved. It is working as I want but user field becomes tag. If I regroup with just measurement, it just resulted as same as first time(getting only last player, u_2)
