Could you check the this questions?
Hello,everyone.
I have created the following database↓
time value1 value2 value3 value4 timestamp
2019-02-28T02:03:00.607441767Z 12345678 12345 12345678901 10000 2019-02-26T14:43:59.812676+0900
2019-02-28T02:03:04.621629874Z 91011120 12345 23456789011 10001 2019-02-26T14:43:59.812752+0900
I want to create the next measurement by use the continuous query↓
time value1 value2 value4 timestamp
2019-02-28T02:03:00.607441767Z 24691356 12345 10000 2019-02-26T14:43:59.812676+0900
2019-02-28T02:03:04.621629874Z 182022240 12345 10001 2019-02-26T14:43:59.812752+0900
Do you know the best continuous queries??
Please let me us know.
best regrads.
Hi ,you can achieve the result without using a continuous query …
A simple select into statement can select the fields you want , or are you planning to aggregate your data ?
The new measurement is not really needed because it will contain a subset of your first measurement … so it will only take space without having a reason to exist ? :slight_smile:
Continuous queries
Hi,MarcV.
Thank you for your responce:grinning:
A simple select into statement can select the fields you want,or are you planning to aggregate your data ?
I’m planning that using continuous queries…
Execute is difficult?
Continuous queries are not difficult to implement , is it only for testing and to learn Influxdb that you want to create a continuous query ?
This is for work,Currntly is test Phase.
However,system implementation will start soon.:sweat_smile:
your continuous query must have a function in the select statement , an INTO
and a GROUP BY TIME() clause.
Do you want to calculate averages for example ?
Hi,MarcV
No,I’m not take calculate averages.
I would like to sum value1 for every value2 and value4.
Hi , i think you need a kapacitor task to do that ,
something like this in a kapacitor tick script … ?
var numbers = stream
|from()
.measurement(‘time’)
|eval(lambda: “value2” + “value4”)
.as(‘value1’)
|influxDBOut()
this will make the sum of value2 and value4 and save it in value1 …
here are some examples :
Kapacitor as a Continuous Query engine
Hi.MarcV.
Thank you quick responce!
I will give it a try!
Maybe this is also interesting ?
> select * from time
1551697213974676426 4      6      9      8
1551698822749869390 4      71     9      41
> select ("value2" + "value4") as value1 into timesum from time where time > now() - 1h
time written
0    2
> select * from timesum
time                value1
1551697213974676426 14
1551698822749869390 112
I’m sorry for the delay…
Thank you for teaching me!
I’ll try this command!
※Now,I’m work to another task…
