Convert "on"/"off" values into 1 and 0
Hi all,
I am grabbing data from an xml url and a few variables are not displayed in a number format but as “on” “off” (or “Aus” / “Ein” in German). is there a way to directly read the data in as 0 and 1?
Many thanks!
[[outputs.influxdb_v2]]
  urls = ["http://192.168.XX.XX:8086"]
  ## Token for authentication.
  token = "XXX"
  organization = "XX"
  bucket = "BAYROL"
  tagexclude =["tag2"]
  [outputs.influxdb_v2.tagpass]
	tag2 = ["BAYROL"]
[[inputs.http]]
  urls = ["http://192.168.XX.XX/cgi-bin/webgui.fcgi?xmlitem=35.6028"]
  data_format = "xml"
  ## Multiple parsing sections are allowed
  [[inputs.http.xpath]]
    metric_selection = "/pm5"
    [inputs.http.xpath.tags]
      id = "id/@name"
    [inputs.http.xpath.fields]
      type = "number(/item/@type)"
      label = "string(/item/@label)"
      unit = "string(/item/@unit)"
      value = "number(/item/@value)"
  [inputs.http.tags]
	tag2 = "BAYROL"
processor enum should do the trick
Hi Giovanni,
Many thanks for the suggestion. I have tried to implement the enum part but I still get the string error. can you help me out there?
  token = "XXX"
  organization = "XX"
  bucket = "BAYROL"
	tag2 = ["BAYROL"]
[[inputs.http]]
  data_format = "xml"
      id = "id/@name"
[[processors.enum]]
	[[processors.enum.mapping]]
	    ## Name of the field to map. Globs accepted.
	    field = "_value"
	    [processors.enum.mapping.value_mappings]
	      "Ein" = 1
	      "Aus" = 0
  [inputs.http.tags]
	tag2 = "BAYROL"
Can’t tell for sure without a sample data point, but something like this should work
[[inputs.http]]
[[processors.enum]]
    field = "value"
      Ein = 1
      Aus = 0
in your example you have interrupted the http.input with the processor, I expect it to don’t even work, or to miss part of the input config (the one after the processor)…
@Globgogabgalab my question is why you want 0 and 1… You could do
      value = "/item/@value='Ein'"
to get a boolean (true = ‘Ein’, else false).
