Convert metric type to Gauge
I have metric collected from a source. the source sets the type of metrics as Info or Stateset.
# HELP capi_cluster_status_phase The clusters current phase.
# TYPE capi_cluster_status_phase stateset
capi_cluster_status_phase{customresource_group="cluster.x-k8s.io",customresource_kind="Cluster",customresource_version="v1beta1",name="somename",namespace="somenamespace",phase="Deleting",uid="50e401fb-9651-47e2-9baf-43d518cea952"} 0
can someone help me understand how we can transform the metric type in telegraf
Hello @rahav_jv,
Telegrafs prom input plugin doesn’t natively support the stateset metric type unfortunately.
However you could try:
  1. Metric filtering to exclude these problematic metrics:
[[inputs.prometheus]]
# Your existing configuration
metric_version = 2
# Exclude the problematic metrics
metric_name_filter = ["capi_cluster_status_phase"]
metric_name_filter_mode = "exclude"
  1. Use the Enum processor to handle these stateset metrics by mapping them to numeric values similar to how Telegraf handles other enumerated states:
[[processors.enum]]
namepass = ["capi_cluster_status_phase"]
[[processors.enum.mapping]]
field = "phase"
[processors.enum.mapping.value_mappings]
Deleting = 0
Failed = 1
# Add other phases as needed
Some resoures that could help
Thanks for your reply. will try it out
