I have a json array coming in over mqtt that looks like the following
"Sensor1": {
"Time": [
1721423157027428600,
1721423157031428600,
1721423157035428600,
1721423157039428600,
1721423157043428600,
1721423157047428600,
1721423157051428600,
1721423157055428600,
1721423157059428600,
1721423157063428600
"Data1": [
0.5375196810086651,
0.9610414132027387,
0.0018270982367867283,
0.3682829898479403,
0.1601324861510789,
0.19179781722154354,
0.930889384682748,
0.49418687417064033,
0.7972837143268192,
0.10455857994855733
What I want is the following is the following influxdb line protocol output
foobar,Sensor1 Data1=0.5375196810086651 1721423157027428600
foobar,Sensor1 Data1=0.9610414132027387 1721423157031428600
foobar,Sensor1 Data1=0.0018270982367867283 1721423157035428600
You get the point
Here is my config
[[inputs.mqtt_consumer]]
servers = ["tcp://127.0.0.1:1883"]
topics = ["sensordata"]
data_format = "json_v2"
measurement_name = "Sensor1"
timestamp_path = "Sensor1.Time.0"
timestamp_format = "unix_ns"
path = "Sensor1.Data1.0"
type = "float"
rename = "Data1"
timestamp_path = "Sensor1.Time.1"
path = "Sensor1.Data1.1"
type = "float"
rename = "Data1"
timestamp_path = "Sensor1.Time.2"
path = "Sensor1.Data1.2"
type = "float"
rename = "Data1"
And this for a total of 10 times.
This produces the result I want, however, i am setting up a config for every single data point.
Is there an easier way to configure Telegraf? I have read through many of the examples in github but i can’t figure out how to do this easier in the config.
Am i doing something wrong?
