Hello @scott,
I want to use a conditional filter in combination with tableFind() to find a table within a stream of tables where the first value = 0 and from that table I would like to extract the value of a tag. How would I do that?
What I have so far:
check = data
|> first()
|> tableFind(fn: (key) => true)
|> getColumn(column: "_value")
if check[0] == 0 then
// Do something with the extracted tag
else
// Do something different with the extracted tag
It extracts the column I would like to check if the first value is zero but only if it is in the first table in the table stream…
How can I check all tables (they only vary by one tag) and extract the value of the tag that separates them?
You’re on the right track. I’d suggest, after your first() call, filtering by rows with a _value of 0. Then in getColumn(), get the tag column to retrieve the value of the tag.
Flux currently doesn’t guarantee the order of tables in a stream of tables, so it’s not possible to check if a table is the first in a stream of tables.
Conditional operators (if, if else, else, then) can only be used inside of a variable declarations or record values. You can’t use them to conditionally fork a function pipeline. What exactly are you trying to do once you have the tag value?
@scott I would like to use a conditional execution to make sure I don’t miss any values. The thing is that I have “on” and “off” values and I am trying to calculate the duration between them. When I am using a flexible time window, it could happen that the first value I get back is a “off” value. With the way I calculate the durations the signal has been active can lead to me getting negative values for durations. When the “off” value is considered to be the first on it subracts a later timestamp from this value. How do I make sure I get only positive durations?
What I was trying to do was to check for which tag-set the first value is zero and then query the previous value for this tag to complete the series…
Yes I do need that first row and filtering out negative durations would not work because if the query returns a “Stop”-Value as the first row, every duration will be negative. I am trying to find a way to still calculate the durations while being able to use a varying time window…
I am currently using a “ugly” solution with the elapsed()-function. This does calculate the durations correctly but it gives me the durations with the wrong timestamps. Because it calculates subsequent rows, I get the “fault_duration” with the timestamp of the “Fault-Stop”-Value. For calculating the sum of the durations or something like that this isn’t a problem but it isn’t the most elegant way.
By the way: Is it possible to test query performance for Flux queries in v1.8.4? When trying to import the profiler package with import "profiler" I receive the error error: unkown import path: "profiler"
Hmm, this is a tricky problem. I think this use case merits a proposal for a new function – trim() or something similar. A function that would let you trim rows off the beginning or end of input tables. You may consider submitting a feature request on the Flux repo.
The version of Flux packaged with InfluxDB 1.8.4 doesn’t support the profiler package. 1.8.5 was recently released and I believe it includes a newer version of Flux, but don’t quote me on that.
