Hi. I have a flux query that has several ‘or’ conditions in a filter function. It’s something like this.
from(bucket: "my_buck")
|> filter(fn: (r) => r["_measurement"] == "my_measurement")
|> filter(fn: (r) => r["idDispositivo"] == "155" or r["idDispositivo"] == "150")
|> aggregateWindow(every: 1h, fn: mean, createEmpty: false)
|> yield(name: "mean")
The example has only one ‘or’ but in the real query there can be several and the query would also be created dynamically. Is there a way to change
for something like
|> filter(fn: (r) => r["idDispositivo"] in ["155", "150"])
I know that this syntax is not correct, but ask if there is something similar that allows me to make the dynamic query easier without having to use so many ‘or’
Thanks in advance
