I updated my home assistant modbus sensor config after getting some more metering equipment. This resulted in a new entity id which in turn pushed the new entity id into influxdb. I also took this time to correct the units which I had defined as lower case to their proper upper case units.
Is there a way to combine these old and new series (and/or measurements?) so that I don’t have two data series? Effectively getting rid of the old one and merging it into the new one?
I would imagine that if it could be done, I would need to do it via the CLI. Since I run this in a container, I can access it via docker exec.
