I have wrong created tag with double quotes : SENSOR = “DOOR”, instead of SENSOR = DOOR, which I can’t remove.
I’m running below command, which does nothing and tag still exists :
influx delete --bucket XXX --predicate '_measurement="XXX" AND SENSOR="\"DOOR\""' --start '1970-01-01T00:00:00Z' --stop '2023-01-01T00:00:00Z
I also tried to remove everything from _measurement and seems like it worked, but then, when new data arrived this tag appeared again. It’s also visible via schema.tagValues.
How can I remove that not removing the bucket?
