hallo i have no problems to use true/false as string, but since influx supports boolean values i would like to use it. here are my test:
#CURL
$curl --request POST “https://ruth:8086/api/v2/write?org=foookin_paavel&bucket=ccc&precision=ms” --header “Authorization: Token …” --data-raw “battery_adc,host=spongebob,BatSenKey=14,BatUlId=50x29196a980,BatCarrier=ttn,BatValid=true BatDecimal=7.64,BatKey=20909 1621759946147”
#CLI
$/usr/bin/docker container exec dck_influxdb influx write -c default --skip-verify -b ccc -p ms “battery_adc,host=spongebob,BatSenKey=14,BatUlId=50x29196a980,BatCarrier=cra,BatValid=true BatDecimal=9.64,BatKey=20911 1621759946160”
#QUERY
$/usr/bin/docker container exec dck_influxdb influx query --skip-verify -c default ‘from(bucket: “ccc”) |> range(start: -24h) |> filter(fn: (r) => r[“_measurement”] == “battery_adc”) |> drop(columns: [“_start”, “_stop”, “host”])’ --raw
#group,false,false,false,false,true,true,true,true,true,true
#datatype,string,long,dateTime:RFC3339,double,string,string,string,string,string,string
#default,_result,
,result,table,_time,_value,BatCarrier,BatSenKey,BatUlId,BatValid,_field,_measurement
,0,2021-05-23T08:52:26.16Z,9.64,cra,14,50x29196a980,true,BatDecimal,battery_adc
,1,2021-05-23T08:52:26.16Z,20911,cra,14,50x29196a980,true,BatKey,battery_adc
but with CURL and CLI a still have tag BatValid as STRING not BOOL
as in Line protocol | InfluxDB OSS 2.0 Documentation
i am not using any quotation mark, but i know influx2 sort this probably by its own as also not using " for string BatUlId -
before every attemp i flush bucket or just delete it, to test on freshly new one
if there is a way i can specify each collumn ( for API_2 via CURL or CLI ) as in CSV import please let me know
thank you, pavel
