I have had influxdb 0.10.0 running very well on Ubuntu 14.04 for over a year. I rebooted and now influx will not start.
I have searched here and googled but not managed to sort it. I found suggestions that it may be a corrupted file and that deleting the wal directory may help. I tried that to no avail.
I thought of upgrading to newer version to see if it gave better diagnostics but I believe I would first have to export the data, which can’t be done unless it is running.
I hope someone here can help as it seems the only other alternative may be to clear the whole database which I am hoping not to have to do. The log is as follows
Aug 17 15:51:29 ade-ubt influxd[28900]: 2018/08/17 15:51:29 InfluxDB starting, version 0.10.0, branch unknown, commit unknown, built unknown
Aug 17 15:51:29 ade-ubt influxd[28900]: 2018/08/17 15:51:29 Go version go1.6rc1, GOMAXPROCS set to 4
Aug 17 15:51:29 ade-ubt influxd[28900]: 2018/08/17 15:51:29 Using configuration at: /etc/influxdb/influxdb.conf
Aug 17 15:51:29 ade-ubt influxd[28900]: [meta] 2018/08/17 15:51:29 Starting meta service
Aug 17 15:51:29 ade-ubt influxd[28900]: [meta] 2018/08/17 15:51:29 Listening on HTTP: 127.0.0.1:8091
Aug 17 15:51:29 ade-ubt influxd[28900]: [metastore] 2018/08/17 15:51:29 Using data dir: /var/lib/influxdb/meta
Aug 17 15:51:29 ade-ubt influxd[28900]: [metastore] 2018/08/17 15:51:29 Node at localhost:8088 [Follower]
Aug 17 15:51:30 ade-ubt Node-RED[25609]: 17 Aug 15:51:30 - [error] [influxdb out:5d011ee3.3c3d18] Error: No host available
Aug 17 15:51:31 ade-ubt influxd[28900]: [metastore] 2018/08/17 15:51:31 Node at localhost:8088 [Leader]. peers=[localhost:8088]
Aug 17 15:51:32 ade-ubt influxd[28900]: [meta] 2018/08/17 15:51:32 127.0.0.1 - - [17/Aug/2018:15:51:32 +0100] GET /?index=0 HTTP/1.1 200 11198 - Go-http-client/1.1 07f4266e-a22d-11e8-8001-000000000000 4.731264ms
Aug 17 15:51:32 ade-ubt influxd[28900]: [store] 2018/08/17 15:51:32 Using data dir: /var/lib/influxdb/data
Aug 17 15:51:32 ade-ubt influxd[28900]: [tsm1wal] 2018/08/17 15:51:32 tsm1 WAL starting with 10485760 segment size
Aug 17 15:51:32 ade-ubt influxd[28900]: [tsm1wal] 2018/08/17 15:51:32 tsm1 WAL writing to /var/lib/influxdb/wal/_internal/monitor/643
Aug 17 15:51:32 ade-ubt influxd[28900]: [filestore]2018/08/17 15:51:32 /var/lib/influxdb/data/_internal/monitor/643/000000001-000000001.tsm (#0) opened in 62.934µs
Aug 17 15:51:32 ade-ubt influxd[28900]: [tsm1wal] 2018/08/17 15:51:32 tsm1 WAL writing to /var/lib/influxdb/wal/_internal/monitor/644
Aug 17 15:51:32 ade-ubt influxd[28900]: [filestore]2018/08/17 15:51:32 /var/lib/influxdb/data/_internal/monitor/644/000000001-000000001.tsm (#0) opened in 44.935µs
Aug 17 15:51:32 ade-ubt influxd[28900]: [tsm1wal] 2018/08/17 15:51:32 tsm1 WAL writing to /var/lib/influxdb/wal/_internal/monitor/645
Aug 17 15:51:32 ade-ubt influxd[28900]: [filestore]2018/08/17 15:51:32 /var/lib/influxdb/data/_internal/monitor/645/000000001-000000001.tsm (#0) opened in 41.532µs
Aug 17 15:51:32 ade-ubt influxd[28900]: [tsm1wal] 2018/08/17 15:51:32 tsm1 WAL writing to /var/lib/influxdb/wal/_internal/monitor/646
Aug 17 15:51:32 ade-ubt influxd[28900]: [filestore]2018/08/17 15:51:32 /var/lib/influxdb/data/_internal/monitor/646/000000001-000000001.tsm (#0) opened in 81.855µs
Aug 17 15:51:32 ade-ubt influxd[28900]: [tsm1wal] 2018/08/17 15:51:32 tsm1 WAL writing to /var/lib/influxdb/wal/_internal/monitor/647
Aug 17 15:51:32 ade-ubt influxd[28900]: [filestore]2018/08/17 15:51:32 /var/lib/influxdb/data/_internal/monitor/647/000000001-000000001.tsm (#0) opened in 42.32µs
Aug 17 15:51:32 ade-ubt influxd[28900]: [tsm1wal] 2018/08/17 15:51:32 tsm1 WAL writing to /var/lib/influxdb/wal/_internal/monitor/649
Aug 17 15:51:32 ade-ubt influxd[28900]: [filestore]2018/08/17 15:51:32 /var/lib/influxdb/data/_internal/monitor/649/000000001-000000001.tsm (#0) opened in 43.248µs
Aug 17 15:51:32 ade-ubt influxd[28900]: [tsm1wal] 2018/08/17 15:51:32 tsm1 WAL writing to /var/lib/influxdb/wal/_internal/monitor/650
Aug 17 15:51:32 ade-ubt influxd[28900]: panic: runtime error: slice bounds out of range
Aug 17 15:51:32 ade-ubt influxd[28900]: goroutine 108 [running]:
Aug 17 15:51:32 ade-ubt influxd[28900]: github.com/influxdb/influxdb/tsdb/engine/tsm1.(*mmapAccessor).init(0xc820485d60, 0x0, 0x0, 0x0, 0x0)
Aug 17 15:51:32 ade-ubt influxd[28900]: #011/build/influxdb-zEZbDw/influxdb-0.10.0+dfsg1/_build/src/github.com/influxdb/influxdb/tsdb/engine/tsm1/reader.go:887 +0x627
Aug 17 15:51:32 ade-ubt influxd[28900]: github.com/influxdb/influxdb/tsdb/engine/tsm1.NewTSMReaderWithOptions(0x0, 0x0, 0xc8201309a0, 0x24ff70e8, 0x0, 0x0)
Aug 17 15:51:32 ade-ubt influxd[28900]: #011/build/influxdb-zEZbDw/influxdb-0.10.0+dfsg1/_build/src/github.com/influxdb/influxdb/tsdb/engine/tsm1/reader.go:154 +0x2dd
Aug 17 15:51:32 ade-ubt influxd[28900]: github.com/influxdb/influxdb/tsdb/engine/tsm1.(*FileStore).Open.func1(0xc820146230, 0xc8202a1680, 0x0, 0xc8201309a0)
Aug 17 15:51:32 ade-ubt influxd[28900]: #011/build/influxdb-zEZbDw/influxdb-0.10.0+dfsg1/_build/src/github.com/influxdb/influxdb/tsdb/engine/tsm1/file_store.go:259 +0x9b
Aug 17 15:51:32 ade-ubt influxd[28900]: created by github.com/influxdb/influxdb/tsdb/engine/tsm1.(*FileStore).Open
Aug 17 15:51:32 ade-ubt influxd[28900]: #011/build/influxdb-zEZbDw/influxdb-0.10.0+dfsg1/_build/src/github.com/influxdb/influxdb/tsdb/engine/tsm1/file_store.go:269 +0x6bb
Aug 17 15:51:32 ade-ubt systemd[1]: influxdb.service: Main process exited, code=exited, status=2/INVALIDARGUMENT
