Can Influx DB Data OSS be a dataset for machine learning data train?
Hello, i am new with Influx DB, i have project for water measurement that measure the water usage in valve and collecting data. Data will collecting flow of water and volume measurement from YF-S201 with MQTT, Data collected will store in Raspberry Pi
My scenario is profiling with clustering based on user time and volume. Example : Time 18 28 - 18 30 the flow is turn to several flow, it detect as washing hand because of the time.
If Influx cannot use in this project what alternative i should use? Thank you.
