Yes, you can create as many field sets (field key + field value) as you want for 1 measurement. The field key is the identifier while the field value is the actual value of your data. But, take into account that fields are not indexed, therefore queries by field will not be as performant compared to tags.
Let me know if this solves your question.
can i make it like this?
@rolandoartha, yes that works great and also great. Note since you are not adding a timestamp that InfluxDB will generate one based on when the data lands
