Hi there,
I have a table for a parking sensor which sends a state for occupied (1) and vacant (9).
Now I want to create a query which shows me the time period between the status changes so that I can create a report for the time the parkingslot was occupied and free.
Can someone help me for creating a query for this?
Thanks!
Please provide more context.
Some sample data?
Do you need a flux or a InfluxQL query?
Thanks for your response.
The table data has actually the following structure:
time----statusnumbered
1646302488500839186----1
1646302488500203666----1
1646302488499932866----1
1646302488499826263----2
hope that helps.
Unfortunately not. Please provide sufficient context.
Where is this data located? In InfluxDB? Or is this your input data?
Which InfluxDB version?
Sorry, my fault.
The data is generated by the parking sensor and inserted via node-red into the influxdb.
The data is located in InfluxDB version 1.8.10 on Ubuntu 20.04.
I would need a InfluxQL query.
Thanks!
