Specifications
- Client Version: Latest NPM version 1.33.2
- InfluxDB Version: Influx Cloud, powered by TSM, storage engine V2, on AWS (free account)
- Platform: Node version 20.11.1 - issue occurs on both Windows and Linux clients
Code sample to reproduce problem
var writeAPI;
try {
writeAPI = influxdb.getWriteApi(influxConfig.org,influxConfig.bucket)
writeAPI.writePoint(point)
writeAPI.flush()
catch(e) {
console.error(e)
finally {
try {
if(writeAPI != undefined)
writeAPI.close()
catch(eClose) {
console.error(eClose)
Expected behavior
I would assume that if there was a write error, that it would be caught. It’s actually surprising how often Influx cloud throws 503 (service unavailable) errors.
Actual behavior
Here is the error that is thrown, and the Node.js process exits when this error occurs.
ERROR: Write to InfluxDB failed. m [HttpError]: 503 Service Unavailable : upstream connect error or disconnect/reset before headers. reset reason: connection termination
at IncomingMessage. (/home/rick/uberbroker/node_modules/@influxdata/influxdb-client/dist/index.js:5:5671)
at IncomingMessage.emit (node:events:530:35)
at endReadableNT (node:internal/streams/readable:1696:12)
at process.processTicksAndRejections (node:internal/process/task_queues:82:21) {
statusCode: 503,
statusMessage: ‘Service Unavailable’,
body: ‘upstream connect error or disconnect/reset before headers. reset reason: connection termination’,
contentType: ‘text/plain’,
_retryAfter: 0
node:internal/process/promises:289
triggerUncaughtException(err, true /* fromPromise */);
statusCode: 503,
_retryAfter: 0
Node.js v20.11.1
Additional info
This happens multiple times per day, and does not appear to be a catchable error. I’m curious:
- why 503 errors happen so often on a hosted service
- why this exception isn’t caught - seems like a client bug
