Anyone Performing Time Series Forecasting or Anomaly Detection?
Hi @gregory_scafarto,
Sorry other business priorities superseded but I’ve been so much looking forward for this.
It will be awesome if you can share the (working) udfs, script anything you got!
Ashish
@Ashish_Sikarwar the udf
from kapacitor.udf.agent import Agent, Handler
from kapacitor.udf import udf_pb2
import sys
import json
import pandas as pd
import numpy as np
from  adtk.src.adtk.data import validate_series
import pickle
import math
import adtk.src.adtk.detector
import logging
from datetime import datetime, timedelta
logging.basicConfig(level=logging.DEBUG, format='%(asctime)s %(levelname)s:%(name)s: %(message)s')
logger = logging.getLogger()
class Anomalies_detection(Handler):
    def __init__(self, agent):
        """Constructor"""
        logger.info('__init__ trigger')
        self._agent = agent
        self._field = ''
        self._size = 25
        self._points = []
        self._time=[]
        self._state = {}
        self.model=""
    def info(self):
        """info: Define what your UDF wants and what will it provide in the end"""
        logger.info('info trigger')
        response = udf_pb2.Response()
        response.info.wants = udf_pb2.BATCH
        response.info.provides = udf_pb2.STREAM
        response.info.options['field'].valueTypes.append(udf_pb2.STRING)
        response.info.options['size'].valueTypes.append(udf_pb2.INT)
        response.info.options['model'].valueTypes.append(udf_pb2.STRING)
        return response
    def init(self, init_req):
        """init: Define what your UDF expects as parameters when parsing the TICKScript"""
        logger.info('INIT trigger')
        for opt in init_req.options:
            if opt.name == 'field':
                self._field = opt.values[0].stringValue
            elif opt.name == 'size':
                self._size = opt.values[0].intValue
            elif opt.name == 'model':
                self.model = opt.values[0].stringValue
        success = True
        msg = ' must provides info'
        if self._field == '':
            success = False
            msg = 'must provide field name'
        response.init.success = success
        response.init.error = msg.encode()
        return response
    def begin_batch(self, begin_req):
        """begin_batch: Do something at the beginning of the batch"""
        self._batch=AD_model(self._size,self.model)
        response.begin.CopyFrom(begin_req)
        self._begin_response = response
        logger.info('begin_batch trigger')
    def point(self, point):
        """point: process each point within the batch"""
        logger.info('point trigger')
        self._batch.update(point.fieldsDouble[self._field],point.time)
    def snapshot(self):
        """snapshot: take a snapshot of the current data, if the task stops for some reason """
        data = {}
        for group, state in self._state.items():
            data[group] = state.snapshot()
        response.snapshot.snapshot = json.dumps(data).encode()
        return response
    def restore(self, restore_req):
        response.restore.success = True
        return response
    def end_batch(self, batch_meta):
        """end_batch: do something at the end of the batch"""
        results=self._batch.test()
        point=results[-1]
        resp = udf_pb2.Response()
        resp.point.name = batch_meta.name
        resp.point.time = self._batch.get_time(len(results)-1)
        resp.point.group = batch_meta.group
        resp.point.tags.update(batch_meta.tags)
        resp.point.fieldsString['metrics'] = "anomalies"
        resp.point.fieldsDouble["value"] = self._batch.get_value(len(results)-1)
        if point ==  1.0 or point == True :
            resp.point.fieldsDouble['val_anomalies'] = 100
        else :
        if type(resp != None) :
            self._agent.write_response(resp)
        else :
            logger.info('pbbbbbb',resp)
        logger.info('end_batch')
    def end_batch_3(self, batch_meta):
        p=0
        for point in results:
            response.point.name = batch_meta.name
            response.point.time = self._batch.get_time(p)
            response.point.group = batch_meta.group
            response.point.tags.update(batch_meta.tags)
            response.point.fieldsString['metrics'] = "anomalies"
            response.point.fieldsDouble["value"] = self._batch.get_value(p)
                response.point.fieldsDouble['val_anomalies'] = 100
            else :
            p=p+1
            self._agent.write_response(response)
class AD_model(object):
    def __init__(self,size,model):
        self.size=size
        self._date=[]
        self._value=[]
        self.model=model
        with open(self.model, 'rb') as f:
            self.model = pickle.load(f)
    def update(self,value,time) :
        self._value.append(value)
        self._date.append(time)
    def test(self):
        self.df=pd.DataFrame({'time':self._date,'y': self._value})
        self.df=self.df.fillna(0)
        self.df=self.df.reset_index(drop=True)
        self.df["time"]=self.df["time"].astype('Int64')
        self.df=self.df.set_index("time")
        self.df.index=pd.to_datetime(self.df.index)
        s = validate_series(self.df["y"])
        val=self.model.detect(s, return_list=False)
        logger.info("les res",val)
        return val
    def get_value(self,p):
        return self._value[p]
    def get_time(self,p):
        return self._date[p]
if __name__ == '__main__':
    # Create an agent
    agent = Agent()
    # Create a handler and pass it an agent so it can write points
    h = Anomalies_detection(agent)
    # Set the handler on the agent
    agent.handler = h
    # anything printed to STDERR from a UDF process gets captured into the logs
    logger.info("Starting agent for Anomalies_detection")
    agent.start()
    agent.wait()
    logger.info("Agent finished")
@Ashish_Sikarwar the class that create the alert
import os
path_to_kap = os.environ['kapacitor']
class Alert():
    def __init__(self, host, measurement):
        self.host = host
        self.measurement = measurement
        self.texte = ""
    def create(self, message, form, pas, path_to_model, field, typo, db):
        self.form = form
        Create the tick alert
        Note : NEED TO DEFINE the path of the script, which will be launched when an alert is trigged, as a variable environnement
        Parameters
        message : str
            Message to be shown as an alert on slack etc ; need to be written with kapacitor syntax
        Returns
        None.
        where_condition = ""
        where = [[element.split("=") for element in form[1:].split(",")][i][0] for i in range(len(form[1:].split(",")))]
        for ele in where:
            where_condition = where_condition + ele + "=" + ele + " AND "
        texte = ""
        tags = ""
        cond = ["var " + (form[1:].replace(",", " AND").split("AND")[i]).replace("=", "='") + "'" for i in
                range(len(form[1:].replace(",", " AND").split("AND")))]
        for element in cond:
            texte = texte + element + "\n"
            tags = tags + ".tag('" + element.split("=")[0] + "'," + element.split("=")[1] + ")\n"
        texte = texte + "\n\n" + """var data = batch
                |query('SELECT """ + typo + """(*) FROM """ + db + """."autogen".""" + self.measurement + """ WHERE """ + where_condition[
        : -5] + """')
                    .period(""" + str(int(25 * pas)) + """m)
                    .every(""" + str(int(pas)) + """m)
                    .groupBy(time(""" + str(int(pas)) + """m))
                data
                  @udf_test()
                    .field('""" + typo + """_""" + field + """')
                    .size(25)
                    .model('""" + path_to_model + """')
                  |alert()
                    .crit(lambda: "val_anomalies" > 10)
                    .message('""" + message + """')
                    .slack()
                  |InfluxDBOut()
                        .database('""" + db + """')
                        .retentionPolicy('autogen')
                        .measurement('anomalies')
                        .tag('measurement','""" + self.measurement + """')\n
                        """ + tags.replace("var ", "")
        self.texte = texte
    def save_alert(self):
        self.form = self.form[1:].replace("=", ".")
        self.form = self.form.replace(",", "_")
        self.form = self.form.replace(":", "")
        self.path = r"Alerte/alerte_" + self.measurement + "_" + self.form + ".tick"
        self.path = self.path.replace(" ", "")
        print(self.path)
        with open(self.path, "w") as f:
            f.write(self.texte)
        f.close()
    def define_alert(self):
        self.form = self.form.replace("=", ".")
        cmd_define_alert = path_to_kap + " define " + "alerte_AD_" + self.measurement + "_" + self.form + " -type batch -tick " + self.path + " -dbrp telegraf.autogen"
        print(cmd_define_alert)
        os.system('cmd /c ' + cmd_define_alert)
    def enable_alert(self):
        cmd_enable_alert = path_to_kap + " enable " + "alerte_AD_" + self.measurement + "_" + self.form
        os.system('cmd /c ' + cmd_enable_alert)
    def launch(self):
        self.define_alert()
        self.enable_alert()
I dont have any alert.tick to show but the class (and the form parameter) is explained here : Community Highlight: How Supralog Built an Online Incremental Machine Learning Pipeline with InfluxDB OSS for Capacity Planning | InfluxData
pas is the granularity
field is the value you want to monitor
typo is the aggregation function
db the database
Thanks a lot @gregory_scafarto !!!
Thanks for sharing. i am watching the seminar and the presenter talked and demo about the anomaly detection via ML (in the services), however, when i checked my influxdb v2, i can’t locate them. Did you manage to find them? thanks
Hello @lchunleo,
That idea was never implemented in InfluxDB. However I appreciate your interest in the topic. Can you please link to the webinar (No-Code ML for Forecasting and Anomaly Detection | InfluxData) and create an issue in both:
GitHub - influxdata/influxdb: Scalable datastore for metrics, events, and real-time analytics
GitHub - influxdata/ui: UI for InfluxDB
If you feel so inclined? I would love to help product prioritize supporting that framework.
Thank you!
