Agent/Plugin startup clarification
Dear community, I’m a noob on Telegraf and InfluxDb therefore sorry in advance if my question sounds stupid :-).
I’m installed Influxdb 2.0 on a docker. I’ve then created a telegraf configuration (load data>telegraf>create configuration) where the setup instruction provide two string (certificate and startup string) to activate the agents on a target server.
I’ve installed Telegraf on a target server and started the agents with the provided string where the conf file is centralized. telegraf --config http://192.168.1.105:8086/api/v2/telegrafs/xxxxxxxxxxxx
The data are collected correctly on by my bucket. I would like now to automatically startup the telegraf agent on boot with this parameter (centralized config file) but I didn’t find any documentation or valid solution.
Usually the agent start with a local config file according to the documentation.
Thanks in advance for the support.
hi @icvdok,
Not a dumb question at all! Also welcome to the community. I will make sure to get this added to the docs. Have you tried editing the Telegraf service:
sudo nano /lib/systemd/system/telegraf.service
Then modifying the service like so:
[Service]
EnvironmentFile=-/etc/default/telegraf
User=telegraf
ExecStart=/usr/bin/telegraf -config http://192.168.1.105:8086/api/v2/telegrafs/xxxxxxxxxxxx -$TELEGRAF_OPTS
ExecReload=/bin/kill -HUP $MAINPID
Restart=on-failure
RestartForceExitStatus=SIGPIPE
KillMode=control-group
Let me know how you get on :slight_smile:
Hello Jay, thanks for the welcome and the reply.
There is no telegraf.service on the system folder, here the output of the systemctl command.
ubuntu@ubuntu:/$ systemctl status telegraf.service
● telegraf.service - The plugin-driven server agent for reporting metrics into InfluxDB
Loaded: loaded (/lib/systemd/system/telegraf.service; disabled; vendor preset: enabled)
Active: failed (Result: exit-code) since Mon 2021-10-18 13:03:22 CEST; 16min ago
Docs: GitHub - influxdata/telegraf: The plugin-driven server agent for collecting & reporting metrics.
Process: 5681 ExecStart=/usr/bin/telegraf -config /etc/telegraf/telegraf.conf -config-directory /etc/telegraf/telegraf.d $TELEGRAF_OPTS (code=exited, status=1/FAILURE)
Main PID: 5681 (code=exited, status=1/FAILURE)
ubuntu@ubuntu:/etc/telegraf$ systemctl status telegraf.service
Loaded: loaded (/lib/systemd/system/telegraf.service; enabled; vendor preset: enabled)
Active: inactive (dead) since Mon 2021-10-18 15:41:21 CEST; 7min ago
Process: 6946 ExecStart=/usr/bin/telegraf -config http://192.168.1.105:8086/api/v2/telegrafs/084bc78a1facc000 -$TELEGRAF_OPTS (code=exited, status=0/SUCCESS)
Main PID: 6946 (code=exited, status=0/SUCCESS)
Oct 18 15:41:21 ubuntu telegraf[6946]: telegraf --input-filter cpu --output-filter influxdb config
Oct 18 15:41:21 ubuntu telegraf[6946]: # run a single telegraf collection, outputting metrics to stdout
Oct 18 15:41:21 ubuntu telegraf[6946]: telegraf --config telegraf.conf --test
Oct 18 15:41:21 ubuntu telegraf[6946]: # run telegraf with all plugins defined in config file
Oct 18 15:41:21 ubuntu telegraf[6946]: # run telegraf, enabling the cpu & memory input, and influxdb output plugins
Oct 18 15:41:21 ubuntu telegraf[6946]: telegraf --config telegraf.conf --input-filter cpu:mem --output-filter influxdb
Oct 18 15:41:21 ubuntu telegraf[6946]: # run telegraf with pprof
Oct 18 15:41:21 ubuntu telegraf[6946]: telegraf --config telegraf.conf --pprof-addr localhost:6060
Oct 18 15:41:21 ubuntu systemd[1]: telegraf.service: Succeeded.
Looks good now, but no data on the bucket
Here some additional info, on my setup, sudo systemctl start telegraf
Add a telegraf.service located in
“/usr/lib/systemd/system/telegraf.service”
with a link to
“/etc/systemd/system/multi-user.target.wants/telegraf.service”
File Telegraf.service
[Unit]
Description=The plugin-driven server agent for reporting metrics into InfluxDB
Documentation=GitHub - influxdata/telegraf: The plugin-driven server agent for collecting & reporting metrics.
After=network.target
[Service]
User=_telegraf
Group=_telegraf
ExecStart=/usr/bin/telegraf --config http://xxx.xxx.xxx.xxx:8086/api/v2/telegrafs/084bc78a1facc000 -$TELEGRAF_OPTS
Restart=on-failure
[Install]
WantedBy=multi-user.target
As in my previous post, it seams to work but no data and no PID found.
Here the journaling output:
Oct 19 07:34:48 HA-homeservices systemd[1]: Started The plugin-driven server agent for reporting metrics into InfluxDB.
Oct 19 07:34:49 HA-homeservices telegraf[2027]: flag provided but not defined: -$TELEGRAF_OPTS
Oct 19 07:34:49 HA-homeservices telegraf[2027]: Telegraf, The plugin-driven server agent for collecting and reporting metrics.
Oct 19 07:34:49 HA-homeservices telegraf[2027]: Usage:
Oct 19 07:34:49 HA-homeservices telegraf[2027]: telegraf [commands|flags]
Oct 19 07:34:49 HA-homeservices telegraf[2027]: The commands & flags are:
Oct 19 07:34:49 HA-homeservices telegraf[2027]: config print out full sample configuration to stdout
Oct 19 07:34:49 HA-homeservices telegraf[2027]: version print the version to stdout
Oct 19 07:34:49 HA-homeservices telegraf[2027]: --aggregator-filter filter the aggregators to enable, separator is :
Oct 19 07:34:49 HA-homeservices telegraf[2027]: --config configuration file to load
Oct 19 07:34:49 HA-homeservices telegraf[2027]: --config-directory directory containing additional *.conf files
Oct 19 07:34:49 HA-homeservices telegraf[2027]: --plugin-directory directory containing *.so files, this directory will be
Oct 19 07:34:49 HA-homeservices telegraf[2027]: searched recursively. Any Plugin found will be loaded
Oct 19 07:34:49 HA-homeservices telegraf[2027]: and namespaced.
Oct 19 07:34:49 HA-homeservices telegraf[2027]: --debug turn on debug logging
Oct 19 07:34:49 HA-homeservices telegraf[2027]: --input-filter filter the inputs to enable, separator is :
Oct 19 07:34:49 HA-homeservices telegraf[2027]: --input-list print available input plugins.
Oct 19 07:34:49 HA-homeservices telegraf[2027]: --output-filter filter the outputs to enable, separator is :
Oct 19 07:34:49 HA-homeservices telegraf[2027]: --output-list print available output plugins.
Oct 19 07:34:49 HA-homeservices telegraf[2027]: --pidfile file to write our pid to
Oct 19 07:34:49 HA-homeservices telegraf[2027]: --pprof-addr pprof address to listen on, don’t activate pprof if empty
Oct 19 07:34:49 HA-homeservices telegraf[2027]: --processor-filter filter the processors to enable, separator is :
Oct 19 07:34:49 HA-homeservices telegraf[2027]: --quiet run in quiet mode
Oct 19 07:34:49 HA-homeservices telegraf[2027]: --section-filter filter config sections to output, separator is :
Oct 19 07:34:49 HA-homeservices telegraf[2027]: Valid values are ‘agent’, ‘global_tags’, ‘outputs’,
Oct 19 07:34:49 HA-homeservices telegraf[2027]: ‘processors’, ‘aggregators’ and ‘inputs’
Oct 19 07:34:49 HA-homeservices telegraf[2027]: --sample-config print out full sample configuration
Oct 19 07:34:49 HA-homeservices telegraf[2027]: --once enable once mode: gather metrics once, write them, and exit
Oct 19 07:34:49 HA-homeservices telegraf[2027]: --test enable test mode: gather metrics once and print them
Oct 19 07:34:49 HA-homeservices telegraf[2027]: --test-wait wait up to this many seconds for service
Oct 19 07:34:49 HA-homeservices telegraf[2027]: inputs to complete in test or once mode
Oct 19 07:34:49 HA-homeservices telegraf[2027]: --usage print usage for a plugin, ie, ‘telegraf --usage mysql’
Oct 19 07:34:49 HA-homeservices telegraf[2027]: --version display the version and exit
Oct 19 07:34:49 HA-homeservices telegraf[2027]: Examples:
Oct 19 07:34:49 HA-homeservices telegraf[2027]: # generate a telegraf config file:
Oct 19 07:34:49 HA-homeservices telegraf[2027]: telegraf config > telegraf.conf
Oct 19 07:34:49 HA-homeservices telegraf[2027]: # generate config with only cpu input & influxdb output plugins defined
Oct 19 07:34:49 HA-homeservices telegraf[2027]: telegraf --input-filter cpu --output-filter influxdb config
Oct 19 07:34:49 HA-homeservices telegraf[2027]: # run a single telegraf collection, outputting metrics to stdout
Oct 19 07:34:49 HA-homeservices telegraf[2027]: telegraf --config telegraf.conf --test
Oct 19 07:34:49 HA-homeservices telegraf[2027]: # run telegraf with all plugins defined in config file
Oct 19 07:34:49 HA-homeservices telegraf[2027]: # run telegraf, enabling the cpu & memory input, and influxdb output plugins
Oct 19 07:34:49 HA-homeservices telegraf[2027]: telegraf --config telegraf.conf --input-filter cpu:mem --output-filter influxdb
Oct 19 07:34:49 HA-homeservices telegraf[2027]: # run telegraf with pprof
Oct 19 07:34:49 HA-homeservices telegraf[2027]: telegraf --config telegraf.conf --pprof-addr localhost:6060
Oct 19 07:34:49 HA-homeservices systemd[1]: telegraf.service: Succeeded.
It seams that something is not working with the -$TELEGRAF_OPTS.
Any idea?
Another question, the PID created, should be listed by the ps command?
Thanks again for the support.
Can you try and remove the environment variable at the end of the command? Looka like Telegraf is having trouble starting because this variable does not exist.
to
Hello Jay, the issue has been solved removing the -$TELEGRAF_OPTS as you suggested. In addition, I’ve to add the variable
INFLUX_TOKEN=<my token>
in the file
Now the agent start automatically and it works.
I get these error now but i suppose it’s an agent issue.
Oct 20 10:45:10 ha-test telegraf[663]: time=“2021-10-20T10:45:10+02:00” level=error msg="failed to create cache directory. /etc/telegraf/.cache/snowflake, err: mkdir /etc/telegraf/.cache: permis
Oct 20 10:45:10 ha-test telegraf[663]: time=“2021-10-20T10:45:10+02:00” level=error msg="failed to open. Ignored. open /etc/telegraf/.cache/snowflake/ocsp_response_cache.json: no such file or di
Now I can start to do something :slight_smile:
Thanks for the support
How did you figure this out?
I created a service and I need to pass the INFLUX_TOKEN to it, otherwise i get a bunch of 401 unauthroized. The INFLUX_TOKEN is an environment variable, so it works fine on the command line, but I want it to be a service in case the machine runs or I dont have to tie up the console.
The machine has influxdbv2 on it and I created a upsd to log UPS data from nut-ups client. It created the token but influxdb2 web ui on port 8086 doesn’t have a workflow for creating, starting and ensuring telegraf is runing on itself as a service.
So I can send it to 127.0.0.1:8086/api/v2/telegraphs/etc… but Googles AI was wrong (they claimed I could pass --env INFLUX_TOKEN=).
I think I figured it out. In my services file I created (/etc/systemd/system/upsd-telegraf.service), I needed to add a line under the [Service] section right above ExecStart=/usr/bin/telegraf --config http://127.0.0.1:8086/api/v2/telefrafs/blah . The line above is Environment=“INFLUX_TOKEN=<token here”.
sudo systemctl start upsd-telegraf.service runs and if I check the status, no error. I check my grafana dashboard and UPS statistics are now poulating my graphs.
