Hello
I’ve defined successfully an influxdb service (using docker-compose) with an initial bucket (telegraf)
version: "3"
services:
influxdb:
container_name: influxdb
image: influxdb
volumes:
- influxdb-storage:/var/lib/influxdb2:rw
env_file:
- .env
entrypoint: ["./entrypoint.sh"]
ports:
- ${DOCKER_INFLUXDB_INIT_PORT}:8086
But now I want to create a second bucket. I tried many ways, but I can’t create it.
Please note that I want that bucket to be created as soon as the container starts.
I know that I have to use the influx CLI.
What I’ve tried:
1st way - using the entrypoint file ./entrypoint.sh (see last line)
#!/bin/bash
# Protects script from continuing with an error
set -eu -o pipefail
# Ensures environment variables are set
export DOCKER_INFLUXDB_INIT_MODE=$DOCKER_INFLUXDB_INIT_MODE
# Conducts initial InfluxDB using the CLI
influx setup --skip-verify --bucket ${DOCKER_INFLUXDB_INIT_BUCKET} --retention ${DOCKER_INFLUXDB_INIT_RETENTION} --token ${DOCKER_INFLUXDB_INIT_ADMIN_TOKEN} --org ${DOCKER_INFLUXDB_INIT_ORG} --username ${DOCKER_INFLUXDB_INIT_USERNAME} --password ${DOCKER_INFLUXDB_INIT_PASSWORD} --host http://${DOCKER_INFLUXDB_INIT_HOST}:8086 --force
influx bucket create -n results -o org -r 120d
in this way nothing happens, no errors but also no bucket with name “results”
2nd way using “command” in docker-compose.yml
i’ve added
services:
influxdb:
command: >
sh -c "influx bucket create -n results -o org -r 120d"
In this way i get this error
Error: failed to lookup org with name “org”: Get “http://localhost:8086/api/v2/orgs?org=org”: dial tcp 127.0.0.1:8086: connect: connection refused
What can I be doing wrong?
cheers
Ricardo
