405 Error when trying to template a task
Has anyone else saw this error when trying to create a template from a task in the web UI? I am using the latest image from docker hub of InfluxDB 2.0.
Failed to save task as template: Error: Request failed with status code 405
Hello @kramik1,
How are you trying to create a template?
I am hovering over a task and using the export option under the gear icon. It shows the JSON and gives me options to save as template, copy to clipboard or download JSON.
