Metrics arrive form telegraf to the influxdb with every minute, but start from +10 seconds.
How can I fix the timestamp to the beginning of each minute?
The input that collects metrics is a kafka consumer.
Thank you.
Thank you.
Can you post the [agent] section of your telegraf config file?
```toml
[agent]
your agent configs here...
[agent]
interval = "60s"
round_interval = true
metric_batch_size = 1000
metric_buffer_limit = 10000
collection_jitter = "0s"
flush_interval = "10s"
flush_jitter = "0s"
precision = ""
hostname = ""
omit_hostname = false
I don’t know how Telegraf works internally and if this is even possible, but you could try with:
interval = "1m"
I assume that the Kafka Input plugin already sets the timestamp?
Otherwise the flush_interval could of course also be the problem.
I have tried setting the interval to “1m” but nothing changes.
When I inspect the influx data in table format, I see that indeed the _time field is always +10s.
All inputs from all plugins have that +10s. Isn’t the telegraf supposed to run every exact minute? (The machine’s clock is correctly synced)
