Hi
I am working with my teammate on yet another csv2influx tool
It can import simple csv files, rename fields and merge dates from multiple columns.
Tested on big datasets.
Looking for feedback.
Hi
Hi Jonyrock. I am not that good at node, but It is pretty sweet. I like the merge fields, does the merge work on non time fields? If so how do you merge different value types together?
I had a chance to look at the code this morning. It looks quite clean. I think tag support is quite important. I suspect it wouldn’t be that big of a change.
I can follow the Issues on github.
Why node? I think python with pandas is easy to do this and if go it will be fastest.
@jiamicu good point. Have no answer yet.
I just like node. I satisfied with performance and costs of development.
Thank you for the advice, really.
