Using script editer to load data always error
when I use script editer to exec this
import "experimental/csv"
csv.from(url: "https://raw.githubusercontent.com/influxdata/influxdb2-sample-data/master/bird-migration-data/bird-migration.csv")
   |> to(bucket:"sample")
always show this error
 failed to initialize execute state: could not find bucket "sample"
I have tried many scripts, they are all such errors, also can not find a solution on the Internet,
@df_df, you need to create a bucket named “sample” in your InfluxDB instance or update the query to write to a bucket you’ve already created. Just replace "sample" with an existing bucket name.
@scott very thanks,and if show this error how could I can fix it ?
error calling function "from" @10:1-10:67: error calling function "get" @experimental/csv/csv.flux|29:39-29:57: context deadline exceeded
this is my script
relativeToNow = (tables=<-) =>
  tables
    |> elapsed()
    |> sort(columns: ["_time"], desc: true)
    |> cumulativeSum(columns: ["elapsed"])
    |> map(fn: (r) => ({ r with _time: time(v: int(v: now()) - (r.elapsed * 1000000000))}))
csv.from(url: "https://influx-testdata.s3.amazonaws.com/noaa.csv")
  |> relativeToNow()
  |> to(bucket: "test-bucket", org: "test-org")
That error essentially means your request to download the CSV is timing out. Are you able to download the CSV file directly?
