Too many failures when attempting to write to udp://localhost:8094, circuit is open
[{ SourceContext: “App.Metrics.Extensions.Hosting.MetricsReporterBackgroundService”,
Reporter App.Metrics.Reporting.Socket.SocketMetricsReporter FlushAsync failed
Hello @kishorekittu76,
Welcome.
Can you please provide more context?
When is this happening? What are you trying to do?
Below is the Context im using to push metrcis from client app
public class MetrcisRegistry
private readonly IMetricsRoot _metrcisRoot;
private readonly CounterOptions _CounterRootOptions = new CounterOptions { Name = “TotalRequests” };
public static string ContextName = “dotcore_ms_requests”;
    public static class Counters
        public static readonly CounterOptions ActiveRequestCount = new CounterOptions
            Context = ContextName,
            Name = "Active",
            MeasurementUnit = Unit.Custom("ActiveRequests"),
            ResetOnReporting = true
        public static readonly CounterOptions TotalErrorRequestCount = new CounterOptions
            Name = "Errors",
            ResetOnReporting = true,
            MeasurementUnit = Unit.Errors
        public static readonly CounterOptions UnhandledExceptionCount = new CounterOptions
            Name = "Exceptions",
            MeasurementUnit = Unit.Errors,
            ReportItemPercentages = false,
            ReportSetItems = false,
    public static class Gauges
        public static readonly GaugeOptions EndpointOneMinuteErrorPercentageRate = new GaugeOptions
            Name = "One Minute Error Percentage Rate Per Endpoint",
            MeasurementUnit = Unit.Requests
        public static readonly GaugeOptions OneMinErrorPercentageRate = new GaugeOptions
            Name = "One Minute Error Percentage Rate",
    public static class Histograms
        public static readonly HistogramOptions PostRequestSizeHistogram = new HistogramOptions
            Name = "POST Size",
            MeasurementUnit = Unit.Bytes
        public static readonly HistogramOptions PutRequestSizeHistogram = new HistogramOptions
            Name = "PUT Size",
        public static readonly HistogramOptions PatchRequestSizeHistogram = new HistogramOptions
            Name = "PATCH Size",
    public static class Meters
        public static readonly MeterOptions EndpointErrorRequestPerStatusCodeRate = new MeterOptions
            Name = "Error Rate Per Endpoint And Status Code",
        public static readonly MeterOptions EndpointErrorRequestRate = new MeterOptions
            Name = "Error Rate Per Endpoint",
        public static readonly MeterOptions ErrorRequestRate = new MeterOptions
            Name = "Error Rate",
        public static readonly MeterOptions httpStatusMeter = new MeterOptions
            Name = "Http Status",
            MeasurementUnit = Unit.Results
        public static readonly MeterOptions userrequest = new MeterOptions
            Name = "userrequest",
            MeasurementUnit = Unit.Requests,
            ReportSetItems=true
    public static class Timers
        public static readonly TimerOptions EndpointRequestTransactionDuration = new TimerOptions
            Name = "RequestEndPointTimer",
            MeasurementUnit = Unit.Calls,
            DurationUnit = TimeUnit.Milliseconds,
            RateUnit = TimeUnit.Milliseconds
        public static readonly TimerOptions RequestTransactionDuration = new TimerOptions
            Name = "RequestStartTimer",
            MeasurementUnit = Unit.Items,
            RateUnit = TimeUnit.Minutes
        public static readonly TimerOptions RequestTransaction = new TimerOptions
            Name = "RequestTimer",
    public static ApdexOptions SampleApdex => new ApdexOptions
        Name = "dotnetcoreApdex"
Hello Anaisdg thanks for your replay ,
Im are using Appmertcis library to capture and send metrics from dotnet core microservices over UDP,we are getting this exception frequently.Too many failures when attempting to write to udp://localhost:8094, circuit is open.
Could you please provide me the solution bcz im getting this exception from last 20 days.If you any information other then i have attached will provide you soon i got reply form you
Flow Description:Steps im doing
MicroService -->Adopted Appmetrcis library to capture Metrics data -->Creating Socket client connection over UDP -->Pushing data to telegraf (using karka credentials)–>From their to Influxdb
When we are working with AppMetrcis in our dotnet core micro services getting Too many failures when attempting to write to udp://localhost:8094, circuit is open: issue
Could you please help me to get rid of this exception
var metrics = new MetricsBuilder()
.Configuration.Configure(
options =>
options.WithGlobalTags((globalTags, info) =>
globalTags.Add(“app”, “RepairApp”);
globalTags.Add(“env”, “stage”);
globalTags.Add(“server”, Environment.MachineName);
.Report.ToInfluxDb(
options =>
options.InfluxDb.BaseUri = new Uri(“http://127.0.0.1:9087”);
options.InfluxDb.Database = “RepairAppInfluxData”;
options.InfluxDb.UserName = “System”;
options.InfluxDb.Password = “123456”;
options.SocketPolicy.BackoffPeriod = TimeSpan.FromSeconds(30);
options.SocketPolicy.FailuresBeforeBackoff = 5;
options.SocketPolicy.Timeout = TimeSpan.FromSeconds(10);
options.FlushInterval = TimeSpan.FromSeconds(5);
.Build();
services.AddMetrics(metrics);
services.AddMetricsReportScheduler();
Hi @kishorekittu76 , I have the same problem, any solution? Tks!!
