I am doing a join in influx to get the first and last values for a interval and then getting the difference.
Preset = 600
FirstValues = from(bucket: "Historian/oneday")
|> range(start: dashboardTime)
|> filter(fn: (r) =>
r._measurement == "TestMeasurement" and
r._field =="Value" and
r.Loc=="TXS"
|>window(every:15m)
|>first()
LastValues = from(bucket: "Historian/oneday")
|> filter(fn: (r) =>
r.Loc=="TXS"
|>window(every:15m)
|>last()
CombinedValues = join (
tables:{first:FirstValues,last:LastValues},
on:["_stop","_start"]
totaliser = CombinedValues
|>map(fn: (r) => ({
_time: r._start,
//Want to do this, r._value_first < r._value_last ? Preset : r._value_first
_value: r._value_first - r._value_last
totaliser
|>window(every:inf)
This works fine till the time difference returns a positive number.
But if the 1st value ,returned from join is less than 2nd value , I want to set perset value as first value (a>b).
Ex:
Preset = 600
|>map(fn: (r) => ({
_time: r._start,
