Telegraph on Vortex86 SoC
telegraf
#1
I want to use Telegraf on a network of several field computer which run Debin with i586 Vortex86 SoC architecture.
I tried several builds but no one could run on my PC.
I would like to make a static complitation on one of my PC and then copy the files to the others PC. Do you think it is possible ?
Thank you
#2
First problem,
The Go linux binary does not run on my PCs:
“This program can only be run on processors with MMX support.”
:frowning:
#3
Best solution is to use Collectd instead of Telegraf…
#4
I’m curious, which architecture of Debian works with this system?
