I am recently reading Telegraf source code, from telegraf/agent.go at master · influxdata/telegraf · GitHub it mentioned AggProcessors.
What is the meaning of AggProcessors and what is the difference between Processors and AggProcessors?
Some light Friday night reading?
The current order of operation in Telegraf is:
- Inputs
- Processors
- Aggregators
- Processors, again
- Outputs
The AggProcessors
are the processors that run after aggregators.
At some point “long ago”, processors were set up to run again after aggregators to be able to modify the output or operate on aggregator output. While this seems harmless, this can also break data if your processors are manipulating or scaling data. We have an open issue to be able to prevent this behavior, but it is not something we have worked on yet.
Good question
Thank you so much for this!!! This confused me for a lot!!!
