Telegraf Controller 1.2 focuses on managing agents. What are they running? Are they healthy? Are they exposed to a published security advisory?
• Security advisories (Telegraf Enterprise only): Controller pulls InfluxData’s signed advisory feed, matches it against the Telegraf version every agent reports, and shows fleet-wide exposure plus the exact agents to update. Air-gapped sites can import the signed file by hand.
• Fleet monitoring: the Agents page provides more details about fleet health, Telegraf version mix, and last-reported recency.
• Per-agent heartbeat data: the agent detail page charts metrics, errors, and warnings per heartbeat and shows a log sample from the latest one, so you can read the output-plugin error behind a data gap without leaving Controller.
• Official Docker image: influxdata/telegraf-controller on Docker Hub.
Give the Docker image a try:
docker run --detach --name telegraf-controller \
--publish 8888:8888 --publish 8000:8000 \
--env TELEGRAF_CONTROLLER_EULA=accept \
--volume telegraf-controller:/var/lib/telegraf-controller \
Also in 1.2:
• Heartbeat service health indicator and API endpoint
• Pre-shared and bootstrap API tokens for infrastructure-as-code
• Real agent IPs behind proxies
• Regex and case-sensitive agent search
• A cleaner OpenAPI document
Links
Announcement blog post: Telegraf Enterprise & Controller 1.2: Know Your Fleet's Security Exposure, Versions, and Health | InfluxData
Release notes: Telegraf Controller release notes | Telegraf Controller Documentation
Download and install: Install Telegraf Controller | Telegraf Controller Documentation
Run in Docker: Run Telegraf Controller in Docker | Telegraf Controller Documentation
Note: If upgrading from an earlier version, read the “Before you upgrade” notes first: audit logging now requires a signing key, and duplicate configuration names are renamed on first start.
