Casey
1
Does the Telegraf agent have an API that can be used to make changes to the agent configuration, start/stop the agent, update configuration, etc?
Hello @Casey,
You can use variables to update the config at start, but no there isn’t an API.
Casey
3
Thanks @Anaisdg
I appreciate the update!
