A measurement cannot be deleted with influx delete.
The command was entered via SSH and appears to have been accepted. However, nothing happens. The command can be aborted with Ctrl+C.
Is there another way to delete it?
Please show us what influx delete command you are trying to use to delete the
measurement.
The command
Show us what command it was.
What tells you that it âappears to have beenâ accepted?
Er, when? After entering the command which appears to have been accepted?
That makes me wonder even more what makes you think it was accepted.
Thatâs good, at least, and strongly indicates that it did not complete.
How are you detecting that the measurement is in the DB?
Antony.
influx delete --org roe75 --bucket iobroker_all --start 2024-03-30T23:00:00Z --stop 2025-05-16T21:00:00.795Z --predicate â_measurement=âRegen_Tagxââ --token PFECvANNR5ZSWbp1csl8e8nQPl7yyeI8LFytWSBfyeByerT3lDnyH_d7pHagKK3g5g_syzy3Q5AIxX5g-_N4jw==
Command was accepted because no error was displayed.If the command were incorrect, an error message would appear immediately.
Measurement was displayed in Data Explorer
attention please:
After logging back into influxdb, the measurement in question disappeared. I interpret this as a successful deletion.
So, the problem appears to have been resolved.
I tested further: If I use influx delete on a nonexistent measurement, the same thing happens as described. However, the two measurements in question were displayed in Data Explorer. Hence the attempt to delete them.
I now suspect that the measurements werenât actually created, but that there was just a display issue.
