# SNMP Traps - output missing descriptions
**URL:** <https://community.influxdata.com/t/snmp-traps-output-missing-descriptions/57576>\
**Category:** Telegraf\
**Tags:** telegraf, grafana, snmp\
**Created:** [July 9, 2025, 11:49am UTC](https://community.influxdata.com/t/snmp-traps-output-missing-descriptions/57576 "2025-07-09T11:49:01Z")\
**Posts on this page:** 3\
**Page:** 1
<div class="post-metadata">
**Author:** ![aerb\_ctus](https://avatars.discourse-cdn.com/v4/letter/a/a587f6/32.png) [@aerb\_ctus](https://community.influxdata.com/u/aerb_ctus)\
**Post date:** [July 9, 2025, 11:49am UTC](https://community.influxdata.com/t/snmp-traps-output-missing-descriptions/57576/1 "2025-07-09T11:49:01Z")
</div>
I have Telegraf set up to receive SNMP traps and output them to Loki for display in Grafana. The traps are picked up and logged, and gosmi is parsing them _mostly_ fine. The output has the MIB, OID, IP address of the device, and the name of the trap, but the description value is missing. The trap’s name is pulled from the MIB file, so I know Telegraf/gosmi can read it.
Is the description something I should be expecting as part of the output?
**Author:** ![Hipska](https://sea1.discourse-cdn.com/flex023/user_avatar/community.influxdata.com/hipska/32/3877_2.png) [@Hipska](https://community.influxdata.com/u/Hipska)\
**Post date:** [July 14, 2025, 7:46am UTC](https://community.influxdata.com/t/snmp-traps-output-missing-descriptions/57576/2 "2025-07-14T07:46:09Z")
</div>
No, descriptions are definitely not a thing you should expect from telegraf. They also aren’t a good fit as time series data.
The name and type of trap should be enough for identifying what it is about. Another db could show this extra info.
**Post date:** [July 14, 2025, 2:08pm UTC](https://community.influxdata.com/t/snmp-traps-output-missing-descriptions/57576/3 "2025-07-14T14:08:49Z")
</div>
That’s disappointing. I get that the trap name “faultiprxsdiVideoPresentSdi1True” _technically_ contains the detail of what’s wrong, but the description “IP Input Video Not Present on Sdi1” is a bit friendlier to the people who will read the alerts.
