Dear influx developers,
I’ve discovered that if you try to store a bunch of “big points” it is just too slow, and consumes lots of CPU.
My test is something like 4 keys with 4-10 possible values, and then something like thousands of field keys with it’s value.
The reason of doing this is the fact that I cannot put some value as a key (due to high card), and I finally opt to use it as the prefix for field keys.
I cannot put this value as another field, because then I will rewrite the point.
Is there any way to achieve this and avoid high cardinality issues with this approach?
Would someone be so kind to explain me why is it so slow and CPU demanding?
My high cardinality version was high mem demanding and went slow when it just hit the TSI limits.
Best regards,
