Slack handler is not enabled
I’m new here and met some problems these days.
I followed the steps in “Creating Chronograf alert rules | Chronograf 1.7 Documentation” and stuck on the step5.
It seems like that my slack (default) handler is not enabled but I don’t know what would be the factor led to this.
Maybe anyone who ever met this problem before.
Thanks,
Steven
Hi Steven
welcome :slight_smile:
the steps you are following assume that there is an existing slack channel on your system,
If you don’t have slack installed , you will have to install it following the link in the steps or use a different alert handler ,
Hope this helps
