i’m using the INTO syntax to create a second measurement, getting data from a first measurement.
However only a part of the data is copied into the second measurement, i have a lots of empty time interval.
The syntax i’m using is the following:
SELECT * INTO measureB FROM measureA WHERE host =~ /.lan./ and time > now() - 1d
Is there a known bug maybe? I did’nt see any error in the log, i’m using influxdb v 1.3.5.
Regards
Francesco
