ts=2018-02-21T00:15:26.029Z lvl=error msg="error evaluating expression for level" service=kapacitor task_master=main task=test2 node=alert2 err="left reference value \"cpu_total_idle\" is missing value" level=CRITICAL
I am receiving the above error on the following tick
dbrp "statsd"."shortterm"
stream
|from()
.measurement('cpu_total_idle')
|alert()
.crit(lambda: "cpu_total_idle" < 70)
.log('/tmp/alerts.log')
The data is there …
select * from cpu_total_idle limit 10
time host metric value
1519171749000000000 tf-p-ubu-sensu-00 cpu-metrics 224818849
1519171759000000000 tf-p-ubu-sensu-00 cpu-metrics 224820808
1519171769000000000 tf-p-ubu-sensu-00 cpu-metrics 224822769
1519171779000000000 tf-p-ubu-sensu-00 cpu-metrics 224824728
I am using sensu with the influxdb udp line protocol.
Thanks !
rob
