Recovery of a database measurement on a website with telegraf
I want to retrieve measurements from a database on the internet with telegraf and send them to influxdb to retrieve them and display them on chronograf. However, I can’t seem to set telegraf to retrieve the values from the “Valeur” section. This is my input plugin and my database on the website :
Sorry for the quality of the screen
Thanks for your feedback
Did you try removing the csv_skip_rows config option, as the header is on the first row? Also, I can’t see if you’ve got a time column, but if not, telegraf will error (visible in the logs). Another option you’ve configured that is difficult to verify is the csv_measurement_column your screenshot is leaving off your csv column labeled measurement_name if it exists. If it doesn’t I suggest removing that configuration as well.
