I’m not really sure, if such a config of inputs.exec should work or not:
[[inputs.exec]] commands = [ "cd /home/dario/Development/python/check_ip_routes && source bin/activate && python run_telegraf.py", ] interval = "60s" timeout = "60s" data_format = "json" name_suffix = "_ip_routes"
If the script is executed, it gives the following output:
{"10.21.217.00/25": 1, "169.254.0.00/16": 0, "172.16.179.00/24": 0, "172.17.0.00/16": 0, "172.18.0.00/24": 0, "192.168.10.00/24": 1}
You should put this login into a shell script and make it executable, then have Telegraf execute that.
