Query with math parsing error
I’m trying to convert Celsius (which is the only value my temp sensor gives through snmp) into Fahrenheit for ease of coworkers viewing the data. I keep getting a parsing error. If I take the +32 off, it works, but obviously not the final value.
select degreesCelsius*9/5+32 from "temp-sensor-01" ERR: error parsing query: found +32, expected FROM at line 1, char 26
Looks like it works with a space between the + and the 32, i.e. x * 9/5 + 32 works. Something in the parser isn’t handling that well. Would you mind opening an issue on GitHub?
Awesome, thanks for catching that. It does in fact fix the problem. I opened up an issue on GitHub.
