My BD contains the current parent of each node. I need to build a flux query to retrieve the path used by a node. For example, in this topology:
4 3
2
1 5
0
Path of 3 = 3, 2, 1, 0
Path of 5 = 5, 0
My current solution is below.
Is there a more generic solution to this problem?
A solution not limited to a fix number of links.
import "experimental/array"
getParent = (tables=<-, children) => tables
|> filter(fn: (r) =>
if length(arr: children) > 0 then
r["node"] == children[0]
else
false)
|> findColumn(fn: (key) => true, column: "parent")
links = [
{ node: 5, parent: 0},
{ node: 4, parent: 2},
{ node: 3, parent: 2},
{ node: 2, parent: 1},
{ node: 1, parent: 0},
parents0 = [4]
parents1 = array.from(rows: links)
|> getParent(children: parents0)
parents2 = array.from(rows: links)
|> getParent(children: parents1)
parents3 = array.from(rows: links)
|> getParent(children: parents2)
parents4 = array.from(rows: links)
|> getParent(children: parents3)
parents5 = array.from(rows: links)
|> getParent(children: parents4)
path = parents0
|> array.concat(v: parents1)
|> array.concat(v: parents2)
|> array.concat(v: parents3)
|> array.concat(v: parents4)
|> array.concat(v: parents5)
|> filter(fn: (r) => contains(value: r.node, set: path))
|> yield(name: "Path")
