How to define resource type and metric label in the stackdriver plugin.we need an example to define the these attributes.
We are getting the following error:
2021-09-15T11:43:37Z E! [inputs.stackdriver] Failed iterating time series responses: “name:"projects/cfs-practice" filter:"metric.type = \"compute.googleapis.com/mirroring/mirrored_bytes_count\" AND resource.labels. = \"\" AND metric.labels. = \"\"" interval:{end_time:{seconds:1631705912} start_time:{seconds:1631705852}}”: rpc error: code = InvalidArgument desc = Field filter had an invalid value of “metric.type = “compute.googleapis.com/mirroring/mirrored_bytes_count” AND resource.labels. = “” AND metric.labels. = “””: Could not parse filter “metric.type = "compute.googleapis.com/mirroring/mirrored_bytes_count" AND resource.labels. = "" AND metric.labels. = ""”; syntax error at line 1, column 90, token ’ ';
syntax error at line 1, column 91, token ‘=’
2021-09-15T11:43:37Z E! [inputs.stackdriver] Failed iterating time series responses: “name:"projects/cfs-practice" filter:"metric.type = \"compute.googleapis.com/nat/received_packets_count\" AND resource.labels. = \"\" AND metric.labels. = \"\"" interval:{end_time:{seconds:1631705912} start_time:{seconds:1631705852}}”: rpc error: code = InvalidArgument desc = Field filter had an invalid value of “metric.type = “compute.googleapis.com/nat/received_packets_count” AND resource.labels. = “” AND metric.labels. = “””: Could not parse filter “metric.type = "compute.googleapis.com/nat/received_packets_count" AND resource.labels. = "" AND metric.labels. = ""”; syntax error at line 1, column 86, token ’ ';
syntax error at line 1, column 87, token ‘=’
