Mysql to influx ql query from grafana
SELECT device_id as Sensor, ROUND(energy - CASE WHEN prev is NULL THEN CASE when cutoff is NULL THEN 0 ELSE cutoff END ELSE prev END,2) as energy, time
FROM(
SELECT sub.*, LAG(energy) OVER (PARTITION BY sub.device_id ORDER BY time ASC) AS prev, cutoff.last_energy as cutoff
FROM(
SELECT
Distinct(device_id) as device_id,
LAST_VALUE(energy) OVER (PARTITION BY device_id||‘-’|| CAST(DATE_TRUNC(‘day’, time) AS VARCHAR) ORDER BY time ROWS BETWEEN UNBOUNDED PRECEDING AND UNBOUNDED FOLLOWING) AS energy,
LAST_VALUE(DATE_TRUNC(‘day’, time)) OVER (PARTITION BY device_id||‘-’|| CAST(DATE_TRUNC(‘day’, time) AS VARCHAR) ORDER BY time ROWS BETWEEN UNBOUNDED PRECEDING AND UNBOUNDED FOLLOWING) AS time
FROM
$energy_measurement
where device_id in (${energy_devices}) and energy !=0 and time >= CAST(‘${start_date}’ AS timestamp)
) sub
Left Join
(SELECT
LAST_VALUE(energy) OVER (PARTITION BY device_id ORDER BY time ROWS BETWEEN UNBOUNDED PRECEDING AND UNBOUNDED FOLLOWING) AS last_energy
FROM
$energy_measurement
WHERE
time <= CAST(‘${start_date}’ AS timestamp) and device_id in (${energy_devices})
) cutoff on sub.device_id=cutoff.device_id
) lagged
help me to convert this to influx ql
@pavbyte The short answer is you won’t be able to convert this query to InfluxQL. InfluxQL simply doesn’t offer the functionality that’s used in your MySQL query (Joins, date-formatting, casting, etc.).
What version of InfluxDB are you using? If you’re using InfluxDB Cloud Serverless, you may be able to do this with straight SQL.
