LoRaWan - Gateway Capacity
I’m trying to gauge how many nodes I can still connect in my LoRaWAN network.
I can currently display how many packet are sent over time according to frequency and application name (see in attached photo). But where do I get information about the Gateway?
Thanks!
Hello @sam5061,
Welcome!!
Hello it depends on the data you have available.
Are you writing Flux from scratch using the Script Editor or using the Query Builder?
I’m assuming Gateway might be a tag?
Maybe you need to do something like group by Gateway with Flux?
