The logparser has trouble getting the NGINX logs located at /var/log/nginx/*_access.log
due to denied permissions.
Logparser output:
Nov 10 21:39:30 central telegraf[16781]: 2018-11-10T21:39:30Z E! Error in plugin [inputs.logparser]: open /var/log/nginx/stats_access.log: permission denied
File permissions:
-rw-r--r-- 1 www-data www-data 276585 Nov 10 00:19 /var/log/nginx/stats_access.log
telegraf
user groups:
telegraf : telegraf www-data docker
Version: Telegraf 1.8.3 (git: HEAD f2979106)
I can provide further info if needed…
Additionally, it doesn’t find any files by pattern /var/log/nginx/*_access.log
unless i use /var/log/nginx/**.log
I have files that are matched by the pattern /var/log/nginx/*_access.log
Example:
ls -l /var/log/nginx/*_access.log
-rw-r--r-- 1 www-data www-data 0 Nov 8 06:25 /var/log/nginx/archive_access.log
-rw-r--r-- 1 www-data www-data 0 Nov 6 06:25 /var/log/nginx/cloud-test_access.log
-rw-r--r-- 1 www-data www-data 1365538 Nov 10 21:55 /var/log/nginx/cloud_access.log
-rw-r--r-- 1 www-data www-data 0 Oct 17 20:28 /var/log/nginx/daemon_access.log
-rw-r--r-- 1 www-data www-data 0 Oct 17 20:28 /var/log/nginx/db_access.log
-rw-r--r-- 1 www-data www-data 296 Nov 10 13:43 /var/log/nginx/dev_access.log
-rw-r--r-- 1 www-data www-data 168584 Nov 10 21:55 /var/log/nginx/download_access.log
-rw-r--r-- 1 www-data www-data 0 Oct 30 06:25 /var/log/nginx/fastdl_access.log
-rw-r--r-- 1 www-data www-data 0 Oct 29 06:25 /var/log/nginx/forum_access.log
-rw-r--r-- 1 www-data www-data 2078162 Nov 10 21:55 /var/log/nginx/grafana_access.log
-rw-r--r-- 1 www-data www-data 504 Nov 10 15:27 /var/log/nginx/homepage_access.log
-rw-r--r-- 1 www-data www-data 0 Oct 17 20:28 /var/log/nginx/portainer_access.log
-rw-r--r-- 1 www-data www-data 367798 Nov 10 21:55 /var/log/nginx/pterodactyl.app_access.log
-rw-r--r-- 1 www-data www-data 156415 Nov 10 21:55 /var/log/nginx/sourcebans_access.log
-rw-r--r-- 1 www-data www-data 0 Oct 17 20:28 /var/log/nginx/status_access.log
-rw-r--r-- 1 www-data www-data 0 Oct 17 20:28 /var/log/nginx/yagpdb_access.log
Fixed it myself, had to run the service as root even if the parser had enough permissions, not sure what the reason behind it is.
