Hello… I’m new to the TICK stack and have been asked to look at a server where kapacitor is not starting up. Another sys admin here stopped telegraf, influxd, and kapacitor on our influx server. In starting those back up, telegraf and influxd lauched fine, but kapacitor does not.
In the /var/log/kapacitor/kapacitor.log, the last several lines are:
[run] 2017/05/30 12:29:12 I! Kapacitor starting, version 1.2.0, branch master, commit 5408057e5a3493d3b5bd38d5d535ea45b587f8ff
[run] 2017/05/30 12:29:12 I! Go version go1.7.4
[srv] 2017/05/30 12:29:12 I! Kapacitor hostname: influx001._myhostname_
[srv] 2017/05/30 12:29:12 I! ClusterID: 8a4df061-c582-411f-bb5a-076c31680c02 ServerID: b74ea789-0bbc-433b-a476-517fb18abd2d
[task_master:main] 2017/05/30 12:29:12 I! opened
[httpd] 2017/05/30 12:29:12 I! Closed HTTP service
[task_master:main] 2017/05/30 12:29:12 I! closed
[run] 2017/05/30 12:29:12 E! open server: open service *task_store.Service: migrating tasks: object already exists
Those lines repeat going back all morning to when kapacitor was shutdown.
The lines following the shutdown are:
[run] 2017/05/30 10:57:08 I! Signal received, initializing clean shutdown...
[run] 2017/05/30 10:57:08 I! Waiting for clean shutdown...
[task_master:main] 2017/05/30 10:57:08 I! Stopped task: puppet_agent_failures
[run] 2017/05/30 10:57:38 I! time limit reached, initializing hard shutdown
So it looks like it was not a graceful shutdown for kapacitor. And now when it starts up, there is some object that already exists that is not allowing the startup.
So what could that object be? How do I clear it out so that kapactior will start correctly?
I have stop/started telegraf, influxd, kapacitor a few times. And have even rebooted the machine entirely. The server is RHEL 7.3. The packages were installed via RPM - kapacitor-1.2.0-1.x86_64, influxdb-1.2.4-1.x86_64, telegraf-1.3.0-1.x86_64.
Appreciate any help and insights, thanks!
-Bob
