Kapacitor marathon service discovery
How can I configure kapacitor to Marathon service discovery?
Which is the marathon api endpoint http://marathon:8080/v2/apps ?
Is it find all my apps with /metrics in prometheus format?
This is the example config from the repo:
[[marathon]]
  enabled = false
  id = "mymarathon"
  servers = []
  timeout = "30s"
  refresh-interval = "30s"
  bearer-token = ""
  ssl-ca = ""
  ssl-cert = ""
  ssl-key = ""
  ssl-server-name = ""
  insecure-skip-verify = false
Does that help get you started?
nope.
What meaning ID ?
What the url I need put in server [ ] http://marathon:8080/ or http://marathon:8080/v2/apps or other ?
tks,
Joao
