Is redundant concurrent ingesting safe?
I have a client API, written in Go, that is gathering chart metrics (from binance) over a websocket. The “keep alive” is unreliable and the websocket keeps dropping the connection, about once every 2-6 hours. What’s the best way to ingest data with an unstable client without dropping points of data?
ideal criteria:
  • I don’t want to monitor my monitor (and then monitor my monitor’s monitor :grin: )
  • I don’t want to drop or miss even a single data point
  • I don’t want to severely impact query times on my dozens of connected grafana charts
With InfluxDb, writes replace each other, right?
Would it cause query issues later, or violate best-practices, if I fired up 2 or 3 processes that all were ingesting the exact same data and restarting themselves whenever their websocket connection drops? I’m pretty sure that with 3 such processes, I’d rarely ever miss any data but I’m concerned that writing the same values at (effectively) the same time would break things. But maybe InfluxDB is built for exactly that use case.
Is it safe to ingest data redundantly and concurrently?
Is there a better approach, perhaps through telegraf or tasks or some other InfluxDb feature designed for this problem?
Hello @gmale,
Welcome!! I don’t think that should be a problem. I think it’s safe, but I’ll send your question to the InfluxDB team just to verify.
Thanks in. advance for your patience.
Thanks! If I distill this down to the root issue, I guess what I’m looking for is whether there are recommended best practices for approaching this common scenario with InfluxDb:
  • I have a “hot” data source (that emits values whether I’m connected or not)
  • I don’t want to drop any data points
In my particular case, the data source is a websocket connection that arbitrarily closes about 10 times per day. However, anyone who monitors data needs to consider how to do so redundantly.
