Hi!
I鈥檓 measuring our energy consumption and supply, store it in influxdb (latest, 2.0.4) and visualize it using Grafana.
Now I want to simulate a battery, for which I need a "cumulativeSum
with constraints (battery full/empty)". I鈥檓 basically stuck with these two issues:
- Proposal: user-defined stateful operators 路 Issue #1256 路 influxdata/flux 路 GitHub
- Iteration over values of time series with flux 路 Issue #2452 路 influxdata/flux 路 GitHub
It seems to be impossible to do a stateful aggregation with flux out-of-the-box. Fine with me, as long as I can hack around that.
I tried the following (full example):
consumed = from(bucket: "default")
|> filter(fn: (r) => r.phase == "Totals" and r._name == "sma_hm_measurements_pconsume_actual")
|> aggregateWindow(every: 1m, fn: mean)
|> keep(columns:["_field", "_time", "_value"])
supplied = from(bucket: "default")
|> filter(fn: (r) => r.phase == "Totals" and r._name == "sma_hm_measurements_psupply_actual")
joined = join(
tables: {consumed:consumed, supplied:supplied},
on: ["_time"]
|> map(fn: (r) => {
return ({
_time: r._time,
_value: r._value,
index: 1
|> cumulativeSum(columns: ["index"])
joined
|> map(fn: (r) => {
// questionable part start
previousIndexRaw = r.index - 2
previousIndex = if previousIndexRaw <= 0 then 0 else previousIndexRaw
previousR = joined
|> getRecord(idx: previousIndex)
previousValue = previousR._value
// questionable part end
diff = r._value_supplied - r._value_consumed
diffScaled = diff / 60.0
newValue = previousValue + diffScaled
newValueClamped = if newValue >= 20000.0 then 20000.0 else if newValue <= 0.0 then 0.0 else newValue
return ({
_time: r._time,
_value: newValueClamped
|> cumulativeSum()
|> aggregateWindow(every: v.windowPeriod, fn: mean)
|> set(key: "_field", value: "Battery")
|> yield()
This gives the following error:
invalid: runtime error @27:4-46:3: map: failed to evaluate map function: unexpected type for table: want {schema: [{grouped: bool | label: string | type: string | t0}]}, got [t5689]
Can someone help me understand why?
Thx!
