In the documentation for the Internal Input it states
internal_<plugin_name> are metrics which are defined on a per-plugin basis, and usually contain tags which differentiate each instance of a particular type of plugin and
version=<telegraf_version>
- internal_<plugin_name>>` .’
When I try to define an internal input for the inputs.file like so :
[[inputs.internal]]
collect_file = true
But I receive the error :
`collect_file’ is not defined in internal.Self
Not sure if I’m referencing the correct plugin name or if the File Input does not support internal inputs. Is there any information regarding which plugins provide support for the internal input?
