I have two queries that are each creating a table. Since I am querying the max & min of the same field I know table A will not contain any entries with the same timestamp as any entry in table B & vice versa.
The two tables are plotted as two traces, but I’d like them plotted as one trace as shown by this yellow line:
is there a way I can interleave the two results so they can be plotted as one table
from(bucket: “gomboc”)
|> filter(fn: (r) => r[“_measurement”] == “20220527-164812/002/”)
|> filter(fn: (r) => r[“_field”] == " … Area")
|> window(every: 1s)
|> max()
|> window(every: inf)
|> yield(name: “max”)
|> window(every: 1s)
|> min()
|> window(every: inf)
|> yield(name: “min”)
Hi @James-O2 welcome to the community! Have you considered using the band visualization to achieve this? Here is an example with my data:
raw = from(bucket: "generators")
|> filter(fn: (r) => r["_measurement"] == "genData")
|> filter(fn: (r) => r["generatorID"] == "generator1")
|> filter(fn: (r) => r["_field"] == "fuel")
|> yield(name: "raw")
mean = raw
|> aggregateWindow(every: 1m, fn: mean, createEmpty: false)
|> yield(name: "mean")
max = raw
|> aggregateWindow(every: 1m, fn: max, createEmpty: false)
|> yield(name: "max")
min = raw
|> aggregateWindow(every: 1m, fn: min, createEmpty: false)
|> yield(name: "min")
