I am sure this is a beginners question and it was already solved somewhere. I tried to google this but did not find anything i can start with.
I have installed indluxdb2. I am updating my info from csv via tail. I have few weather stations on the roof and they are updating my database well. I have an odd issue with my measurements. All is working when the temperatures are above 1C or bellow 0C. BUT when the temperatures are bigger than 0 and smaller then 1 the influx is showing them as meters.
Would appreciate any advise from where i can start to mitigate this issue.
[update]
Or is this a way the influx works with mili? If so or not how do I get rid of it?
Thanks!
