I have x and y fields in influx. I am trying to write a flux query which defines a threshold value 2 or more and creates new column binary starting with value 0 and then next values depend on the changes in x, y or both. lets say x changes with threshold 2 or more then my second value in binary field(column) becomes 1(opposite to previous value zero). so value of binary column would toggle between 0 and 1 based on changes in x or y or both.below is my query but throwing error - Can I please get a help on this?
threshold = 2.0
from(bucket: “fluxbucket”)
|> range(start: -1000h) // Adjust the time range as needed
|> filter(fn: (r) => r._measurement == “random_coordinates”)
|> pivot(rowKey:[“_time”], columnKey: [“_field”], valueColumn: “_value”)
|> sort(columns: [“_time”])
|> difference(columns: [“x”, “y”], nonNegative: false)
|> map(fn: (r) => ({
_time: r._time,
x: r.x,
y: r.y,
x_change: if abs(r.x) >= threshold then 1 else 0,
y_change: if abs(r.y) >= threshold then 1 else 0
|> map(fn: (r) => ({
_time: r._time,
x: r.x,
y: r.y,
x_change: r.x_change,
y_change: r.y_change,
change_detected: if r.x_change == 1 or r.y_change == 1 then 1 else 0
|> aggregateWindow(every: inf, fn: (tables=<-) => tables
|> reduce(
fn: (r, accumulator) => ({
_time: r._time,
x: r.x,
y: r.y,
change_detected: r.change_detected,
binary_state: if r.change_detected == 1 then (accumulator.binary_state + 1) % 2 else accumulator.binary_state
identity: {binary_state: 0}
|> yield(name: “result”)
